[Hexapod] Too many objects to add in collision check
ravi
Re: [Hexapod] Too many objects to add in collision check
Post by ravi » 05 Mar 2018, 14:59
coppelia wrote:
05 Mar 2018, 07:28
Each motor's black axis will collide with the robot's white shapes.
yes, you are right. I noticed it.
coppelia wrote:
05 Mar 2018, 07:28
You either need to modify the shapes, or shift them a little bit until they do not collide anymore.
Please see the attached screenshot below:
https://www.dropbox.com/s/dij965tk941u5 ... t.png?dl=0
I think that if I can cut the highlighted portion (in orange color) from each motor, the problem can be solved. However, I don't see any option to select and modify/cut some part of a compound shape.
See the scene file below:
https://www.dropbox.com/s/ov0hud9gdpqtv ... 2.ttt?dl=0
What do you suggest?
Post by coppelia » 06 Mar 2018, 09:09
You have 2 possibilities:
  • decompose compound shapes, edit the component, regroup the compound shape. This is quite troublesome.
  • simply attach auxiliary cuboid shapes to each motor. Make them invisible. Then use the cuboid shapes instead of the motor shapes in the collection
ravi
Post by ravi » 08 Mar 2018, 11:01
Thank you very much.
I simply removed all the motors. the model looks weird but working!
