recording Video crashes
vrepUser94
Post by vrepUser94 » 21 Mar 2018, 07:36
recently some problem with the V-REP internal video recorder occurred.
Although everything has already worked well, I suddenly get an error "The video compressor failed initializing. Check the console for additional messages."
I don't really get any further information what the error comes from.
Actually the recorder is working when I start it "manually", but when I start it from a customization script (with sim.setBoolParameter(sim.boolparam_video_recording_triggered,1)), which is the wanted way in my case, the error occurs.
I have never had this problem before, so I have no idea how to solve the issue.
Thanks for your help
Re: recording Video crashes
Post by coppelia » 21 Mar 2018, 11:53
I cannot reproduce your crash. Please confirm that following crashes:
  • create an empty scene
  • add a customization script to an object
  • in the init phase of the customization script, add sim.setBoolParameter(sim.boolparam_video_recording_triggered,1)
  • run the simulation
Did you try to use a different video encoder type?
vrepUser94
Post by vrepUser94 » 22 Mar 2018, 15:43
Hello again,
thanks for your answer!
I don't really know what happened, but the error is suddenly gone, although the whole setup of my simulation is the same.
Maybe the old-fashioned method of shutting down the computer and restarting it today helped ;)
If the error occurs again I'll catch necessary information for debugging.
Thanks for the quick and perfect support you give all the time by the way.
