Import a map.obj
Posted: 12 Apr 2018, 10:38
by raulortiz
Hi, I have imported a map from OpenStreetMap in the format.obj and everything is correct but when I try to put a vehicle inside the map it fall down because there is no floor under it. Besides, if I put the map over the floor the vehicle do not stop when it crashes against a building , it is like you can see everything but it does not exist. How can I solve it ?.
Thanks!!!!
Re: Import a map.obj
Posted: 16 Apr 2018, 06:23
if you import a mesh, then you obtain one or several shapes. Those do not have any dynamic properties at first (i.e. they are static and non-respondable). Make sure to carefully read
this section for details.
Posted: 17 Apr 2018, 09:01
by raulortiz
Okay , thank you for your reply. In this case, several shapes are imported and they are non-respondable. Is possible to convert them to respondable?.
Kind regards.
Posted: 17 Apr 2018, 17:18
Yes, did you read the link I provided?
Posted: 18 Apr 2018, 11:35
by raulortiz
Yes, I did. It is solved now. Thank you very much
