Import a map.obj
raulortiz
Import a map.obj
Post by raulortiz »
Hi, I have imported a map from OpenStreetMap in the format.obj and everything is correct but when I try to put a vehicle inside the map it fall down because there is no floor under it. Besides, if I put the map over the floor the vehicle do not stop when it crashes against a building , it is like you can see everything but it does not exist. How can I solve it ?.
Thanks!!!!
Re: Import a map.obj
if you import a mesh, then you obtain one or several shapes. Those do not have any dynamic properties at first (i.e. they are static and non-respondable). Make sure to carefully read this section for details.
raulortiz
Post by raulortiz »
Okay , thank you for your reply. In this case, several shapes are imported and they are non-respondable. Is possible to convert them to respondable?.
Kind regards.
Yes, did you read the link I provided?
raulortiz
Post by raulortiz »
Yes, I did. It is solved now. Thank you very much
