After importing a mesh(.obj), it is transparent
Zhuang
Post by Zhuang »
Hi, everybody
I try to import a shape (.obj) into vrep(3.5.4) . but it is transparent in vrep even if i change layers. the mesh(with text) can be displayed in meshlab.
how to deal with the problem?
Re: After importing a mesh(.obj), it is transparent
when you say transparent, you mean invisible?
Then, it can be that you have one of following situaions:
  • the mesh is extremely large and you cannot see it
  • the mesh is extremely small and you cannot see it
  • the mesh is somehow corrupt. But this situation normally doesn't happen.
You can select it, and scale it up/down to see if it suddenly appears. You can inspect the size of a shape's bounding box in this dialog.
Zhuang
Post by Zhuang »
coppelia wrote: 17 Apr 2018, 17:23 Hello,
Hello, coppelia
thank u for your answer.
when I click it the model, i can see its bounding box. but it is not invisible like air. and I think its size is fitting in the sense.
there is the model file (.obj):https://www.dropbox.com/s/w6w8ar7iza043 ... ar.gz?dl=0
cheers
Your imported mesh has a color opacity of zero. Uncheck the Opacity box simply, in the color dialog for the shape.
Don't know how the import operation picked that up from the files
