Why place where i set string signal affects robot movement?
mareurbanek
Post by mareurbanek »
Hello, I'm writing code where i want to communicate between several components, so i can control cooperation between them. When I'm setting string signal in IRB4600#1 on 122'th line of script, then IRB4600#2 receives that signal and perform as expected, but when i set string signal any further in my IRB4600#1 (script line > 122) then IRB4600#2 still receives that signal, but doesn't move (target moves, but robot doesn't follow).
I came across this problem before, but i solved it by setting signal earlier in the code and sim.wait() in another robot. What am I doing wrong or don't understand? Maybe there is a better way to communicate between several robots and components?
Here is my scene: http://s000.tinyupload.com/index.php?fi ... 2897558066
Re: Why place where i set string signal affects robot movement?
signals should be used carefully, since you should see then as global variables. If you set that variable several times before another script runs, then only the last set variable will be read (i.e. signals are variables, not buffers). If you want robot1 be able to send data to robot2 without losing intermediate states, then you can use something like (in case you wish to use signals):
Robot1:
function writeValue(newValue)
    -- sim.setThreadAutomaticSwitch(false) -- if in a threaded child script
    local val=sim.getStringSignal('myCommunicationChannel') -- read existing data
    if not val then
        val={}
        val=sim.unpackTable(val)
    val[#val+1]=newValue -- append new data
    sim.setStringSignal('myCommunicationChannel',sim.packTable(val)) -- write updated data
    -- sim.setThreadAutomaticSwitch(true) -- if in a threaded child script
Robot2:
function readValue()
    local retVal=nil
    local val=sim.getStringSignal('myCommunicationChannel') -- read data
    if val then
        if #val>0 then
            retVal=table.remove(val,1) -- remove one data item
    return retVal
mareurbanek
Thank you for your answer. I found that using sim.waitForSignal and setting integer signals in another robot gives me the best results.
