How I can implement multi-robots path planning with evolutionary methods like pso in v-rep
ariyayi
Post by ariyayi » 10 May 2018, 08:29
I used distributed approach that each robot make independent decision, coordinate to determine the next position from its current position in the word map(include obstacle) by evolutionary methods like particle swarm optimization. My algorithm gets the current position of robot and call PSO function to find next position in sensing range. For each step it will call PSO until reach predefined goal position.
I wrote my code in Matlab and also I connected it by remote API. I want to know if it is possible to write it on child scripts(Threaded child scripts or Non-Threaded child scripts?) for each robot or what is the best way to implement it in v-rep. thanks
Re: How I can implement multi-robots path planning with evolutionary methods like pso in v-rep
Post by coppelia » 11 May 2018, 08:00
since you have a very distributed system, you can ideally do this directly with child scripts, since each child script will run independently from the others (i.e. each script has its own isolated state). Normally you would design one robot with its navigation/path planning algorithm inside of a chiuld script attached to it. Then, you can duplicate that robot as often as needed, creating several independent robots.
ariyayi
Post by ariyayi » 20 May 2018, 15:08
hi , thanks for your replay
I used Threaded child scripts for khepera Iv robot in simulation , and write PSO function before
function sysCall_threadmain() , my path planning algorithm work correctly, Know I insert another kheprea Iv and two other dummy 'End' and 'begin' in scene. I copy all code in first one child script in second khepera IV robot and change
robotHandle=sim.getObjectHandle('Khepera_IV')
    rightMotor=sim.getObjectHandle('K4_Right_Motor')
    leftMotor=sim.getObjectHandle('K4_Left_Motor')
    targetHandle=sim.getObjectHandle('Goal')
   startHandle=sim.getObjectHandle('Start')
to
robotHandle=sim.getObjectHandle('Khepera_IV#0')
    rightMotor=sim.getObjectHandle('K4_Right_Motor#0')
    leftMotor=sim.getObjectHandle('K4_Left_Motor#0')
    targetHandle=sim.getObjectHandle('End')  -- it's line 227
    beginHandle=sim.getObjectHandle('Begin')
when I run it :
Lua runtime error: [string "CHILD SCRIPT Khepera_IV#0"]:227: Object does not exist. (sim.getObjectHandle)
stack traceback:
[C]: in function 'getObjectHandle'
[string "CHILD SCRIPT Khepera_IV#0"]:227: in function <[string "CHILD SCRIPT Khepera_IV#0"]:220>
ariyayi
Post by ariyayi » 20 May 2018, 15:59
I fixed it , In scene hierarchy in simulation I changed 'End' and 'Begin' to 'End#0' and 'Begin#0' and in child script I changed
Threaded child scripts robot 1
    beginHandle=sim.getObjectHandle('Start')
Threaded child scripts robot 2
    targetHandle=sim.getObjectHandle('End#0')
    beginHandle=sim.getObjectHandle('Begin#0')
It works correctly.
