Get image from vision sensor in Python
Anton
Post by Anton » 13 May 2018, 11:28
Hi everyone,
I want to make a line-follower robot using a camera in V-REP. I'm able to move the robot arround using Python 3.6. Now I'm trying to get the image from the vision sensor in Python, but it gives me an error. This is the code I am using:
import vrep
import numpy
import cv2
import time
import sys
vrep.simxFinish(-1)
clientID = vrep.simxStart('127.0.0.1',19999,True,True,5000,5) # Connect to V-REP
if clientID != -1:
    print ('Connected to remote API server')
else:
    print ('Failed connecting to remote API server')
    sys.exit()
errorCode, camera_handle = vrep.simxGetObjectHandle(clientID, 'cam1', vrep.simx_opmode_blocking)
print (errorCode)
errorCode, resolution, image = vrep.simxGetVisionSensorImage(clientID, camera_handle, 0, vrep.simx_opmode_streaming)
print (resolution)
print (image)
print (errorCode)
The first errorCode is 0, but the second one is 1 and resolution and image are both empty.
What am I doing wrong?
Thanks in advance
Re: Get image from vision sensor in Python
Post by coppelia » 15 May 2018, 08:25
please carefully read about how to stream data via the remote API.
Here a working example:
import vrep
print 'Program started'
vrep.simxFinish(-1) # just in case, close all opened connections
clientID=vrep.simxStart('127.0.0.1',19999,True,True,5000,5)
if clientID!=-1:
    print 'Connected to remote API server'
    res,v0=vrep.simxGetObjectHandle(clientID,'Vision_sensor',vrep.simx_opmode_oneshot_wait)
    res,v1=vrep.simxGetObjectHandle(clientID,'PassiveVision_sensor',vrep.simx_opmode_oneshot_wait)
    res,resolution,image=vrep.simxGetVisionSensorImage(clientID,v0,0,vrep.simx_opmode_streaming)
    while (vrep.simxGetConnectionId(clientID)!=-1):
        res,resolution,image=vrep.simxGetVisionSensorImage(clientID,v0,0,vrep.simx_opmode_buffer)
        if res==vrep.simx_return_ok:
            res=vrep.simxSetVisionSensorImage(clientID,v1,image,0,vrep.simx_opmode_oneshot)
    vrep.simxFinish(clientID)
else:
    print 'Failed connecting to remote API server'
print 'Program ended'
