Quadcopter becomes unstable at scales of <=40%
Rex
Post by Rex »
Hi, I've tried scaling the default quadcopter down and noticed that it becomes unstable at <=40% (i.e exploding).
May I know is this due to a threshold on the minimum size required of the components, or is it caused by something else?
Thanks in advance!
Re: Quadcopter becomes unstable at scales of <=40%
you will have to adjust the quadcopter controller code if you scale the quadcopter.
Rex
Post by Rex »
Hi Coppella, thanks for the advice.
In general, is there a minimum size each dynamic shape should have if I were to scale models down to really small sizes? I.E 2% of original size, assuming the parameters of the models' child script have been retuned for the new scale
Thanks!
This depends a lot on the physics engine you use, and its settings/parameters. For instance, with Bullet, you have a parameter internal scaling that can be adjusted in order to overcome some of the limitations.
