sim.checkProximitySensor always returns result = 1
Posted: 21 Jun 2018, 15:14
I'm trying to work with proximity sensors and I encountered a problem with the sim.checkProximitySensor function : it seems that it always detects the object I'm passing as argument.
My scene is very simple : a ray type proximity sensor is attached to a robot leg. A static, respondable shape is approached to the sensor until contact (I do this manually).
Here is my code:
No matter where I put the cube, res_FL is always 1.
The strange thing is that dist_FL is "nil" when the cube is not in the sensor range, which contradicts the fact that res_FL is 1 (ref. to the function documentation).
Explicit handling or not doesn't change the output.
I think I don't understand how the sim.checkProximitySensor is supposed to work. Can you help me with that?
Best,
Maxens
Here is my code:
-- attached to each leg tip
function sysCall_init()
prox_FL = sim.getObjectHandle("prox_FL") -- proximity sensor on leg tip
-- sensor range is 0.002m in front of leg tip
dummy_tip_FL = sim.getObjectHandle("dummy_tip_FL")
tar = sim.getObjectHandle("tar") -- target
cub = sim.getObjectHandle("Cuboid") -- static cube shape
function sysCall_sensing()
res_FL, dist_FL, det_pt_FL = sim.checkProximitySensor(prox_FL, cub)
if res_FL then -- we detect the cube in front of the foot
print(dist_FL)
Best,
Maxens
