Display Image from Vision Sensor
davide.barchi
Post by davide.barchi » 22 Jun 2018, 11:20
Hi, i've encountered a problem similar to viewtopic.php?t=5565
Basically, I have to read an Image from a Vision Sensor and then display it through a floating view. The final goal would be display the depth buffer coming out from the sensor through a grey scale image.
In order to do that, I would like to check first of all the the possibility to display a general Image, so I've done the folliwing operations:
1) Add the sensor that will read the image
2) Add a second vision sensor with an associated floating view, checked its "External Input" and "Explicit Handling"
3) run the bottom code in a non thread child script:
    VisionH15Handle = sim.getObjectHandle('VisionH15') -- this will read the image
    DispalyHandle = sim.getObjectHandle('DisplayVisionSensor') -- this will display the image
function sysCall_actuation()
    imageBuffer=sim.getVisionSensorCharImage(VisionH15Handle,0,0,0,0,0)
    if(imageBuffer == nil) then
        print('error')
    rv = sim.setVisionSensorImage(DispalyHandle,imageBuffer)
    print('debug',rv)
However, the output is always:
debug,-1
debug,-1
debug,-1
debug,-1
debug,-1
debug,-1
debug,-1
What am i missing?
Davide
Re: Display Image from Vision Sensor
Post by coppelia » 23 Jun 2018, 18:20
are you sure the two vision sensors have the same resolution? Also, what happens if you use sim.setVisionSensorCharImage instead?
Also, you probably know that you can directly display the image or depth map of a vision sensor in a floating view, without the need to hand over the image to another vision sensor.
davide.barchi
Post by davide.barchi » 25 Jun 2018, 07:36
coppelia wrote:
23 Jun 2018, 18:20
Actually the problem was this one. Thanks!
coppelia wrote:
23 Jun 2018, 18:20
I know i can display directy an image in the floating view, what about the deph map?
Davide
Post by coppelia » 27 Jun 2018, 10:06
Yes, you can also directly display the depth map. In that case you first need to replace the filter Original image to work image with Original depth image to work image.
