Set Shape Inertia with Matlab API
tgurriet
Post by tgurriet » 16 Jul 2018, 12:47
I cannot find a way to set the inertia of a body with the Matlab API. The function "simSetShapeMassAndInertia" is not implemented and there are no inertia parameter in : http://www.coppeliarobotics.com/helpFil ... terIDs.htm.
Does anyone have a solution to set the Inertial frame (orientation/translation) and the inertia matrix?
Thanks in advance,
Tom
Irving
Re: Set Shape Inertia with Matlab API
Post by Irving » 18 Jul 2018, 16:33
I'm sure Coppelia will confirm this but I suspect the answer is to write a custom function in a V-REP child script and call that from Matlab using simxCallScriptFunction
I've had to do this for a couple of functions...
tgurriet
Post by tgurriet » 18 Jul 2018, 17:11
It's definitly one way to go, but that functionality is kinda important, it would be great to have the "simSetShapeMassAndInertia" function implemented in the API directly.
Post by coppelia » 20 Jul 2018, 07:38
yes, Irving is right, currently this is your best option. You could of course also modify the remote API, which is currently overkill. The next version of the remote API will be based on BlueZero, and very easily extendible. Should be available in next release.
