generate path from sim.generateIkPath
davide.barchi
Post by davide.barchi »
Hi, i am working on a simple application about a manipulator's path plannig. On the basis of the example "motionPlanningDemo1" i started doing my scene. In particular, the first step i would like to check is the generation of an inverse kinematic path computed by sim.generateIkPath. For this porpouse, the logic that the following code uses is:
- generate the destination pose i want to reach from a non threated child script and set the command to the robot trought an integer signal
- associate to a minipulator a non threated child script that is always listening to the previous signal in order to start its mission. Once the command is given, it has to move from its actual config to the table6_source position through a straight line path. For simplicity, no collisions are considered.
The child script associated to the manipulator is (avoiding initialization part):
function sysCall_actuation()
    if stateMan == 0 then
        if sim.getIntegerSignal('Do Manipulator Mission') == 1 then
            local boxPosHandle = sim.getObjectHandle('TestTarget')
            local pos=sim.getObjectPosition(boxPosHandle,-1)
            local orientation=sim.getObjectOrientation(boxPosHandle,-1)
            table6_source={pos[1],pos[2],pos[3], orientation[1],orientation[2],orientation[3]}
            stateMan = 1
    if stateMan == 1 then
        --move orientation target to the dst position
        print('move orientation target to ',table6_source)
        sim.setObjectPosition(orientationTargetHandle,-1,{table6_source[1],table6_source[2],table6_source[3]})
        --shift along desired axis
        local m = sim.getObjectMatrix(orientationTargetHandle,-1)
        m = getMatrixShiftedAlongAxis(m,-0.8,2) -- shoft along the z axis, a personal modification about original function
        sim.setObjectPosition(orientationTargetHandle,-1,{m[4],m[8],m[12]}) -- this position is checked, it's ok!
        -- Compute a straight-line path from current config to pose m:
        path=generateIkPath(getConfig(),m,ikSteps)
        if path == nil then
            print('null path')
        -- Follow the path:
        followPath(path)
        stateMan = 2
    if stateMan ==2 then
        print('end')
        sim.setIntegerSignal('Do Manipulator Mission',0)
        stateMan = 0
Where the function generateIkPath is :
generateIkPath=function(startConfig,goalPose,steps)
    -- Generates (if possible) a linear, collision free path between a robot config and a target pose
    local currentConfig=getConfig()
    setConfig(startConfig)
    sim.setObjectMatrix(ikTarget,-1,goalPose)
    ikCalculationResult,jointValues=sim.checkIkGroup(ikGroup,jh,nil)
    print('results from ik check',ikCalculationResult,jointValues)
    local c=sim.generateIkPath(ikGroup,jh,steps,nil,nil)
    setConfig(currentConfig)
    return c
The problem is that the code is printing null path, meaning that the API sim.generateIkPath is not working. The pose is reachable, ikGroup is checked and the robot use is the one copied from the mentioned Demo.
What am i missing?
Cheers,
Davide
Re: generate path from sim.generateIkPath
please post your scene, it is impossible to say otherwise what is going wrong.
