Sensor Image with C++
jegovila
Post by jegovila » 03 Sep 2013, 22:24
Hello
I am trying to send an image from V-REP to C++. I am familiar with image processing in Matlab and I am trying to do something like that in C++, i.e. sending an image as a 2-D matrix and access to each pixel and its intensity (0-255).
I saw the Api function "simxGetVisionSensorImage", and one of the parameters is the image that is a pointer to a pointer. I tried this:
int resolution[2];
resolution[0]=100;
resolution[1]=100;
char **image=NULL;
	simxGetVisionSensorImage(clientID,vision,resolution,image,0,simx_opmode_streaming);
	printf("%d \n",*(*(image+1)+2));
And I expected to receive the intensity value for the pixel in the first row and second column (image[1][2]) but the client just stop working.
Then I thought that I had to specify the size of the data I am going to receive and I tried to add something like this:
char *image1=(char *) malloc(65000);
image= &image1;
But It did not work...
There is a way to access to the data of the image just like matlab? i.e. to each pixel of the 2-D matrix?
Thanks!
Re: Sensor Image with C++
Post by coppelia » 04 Sep 2013, 09:49
Have a look at this post, which illustrates how to use simxGetVisionSensorDepthBuffer. simxGetVisionSensorImage basically works in a similar way, except that you have 3 times more values (for the red, green and blue components).
