Read proximity from threaded script
fullmanido
Post by fullmanido » 31 Jul 2018, 22:19
Hello, I am trying to enable a robot if the sensor is active. I have the proximity in a non-threaded script, now I need to update the signal in the threaded script. The packed table needs to be monitored, should I use a parameter?
--threaded script
setTestData=function(bool)
conveyorName='ConveyorBelt'
   data=simGetStringSignal(conveyorName..'_CBS1')
    if data then
        CBSData=simUnpackFloatTable(data)
        CBS1Sesnor1=(CBSData[1])
        CBS1Sesnor2=(CBSData[2])
thanks!
Re: Read proximity from threaded script
Post by coppelia » 03 Aug 2018, 05:51
not sure I understand your question. Why not simply printing the unpacked table to the status bar, e.g.:
if data then
    print("Sensor1",CBS1Sesnor1)
    print("Sensor2",CBS1Sesnor2)
fullmanido
Post by fullmanido » 03 Aug 2018, 22:01
Thank you for your reply. I am trying to send an "OK to run" signal to the UR5 example. The proximity is located at the end if the conveyor, I don't want the robot to initialize without an object present on the conveyor. I really need a global variable that I can transfer from a Non-threaded script to a while loop in a threaded script.
---Conveyor code (not-threaded)
-- would like to send the signal to a threaded while loop
             if simReadProximitySensor(sensor)>0 then
                 beltVelocity=0
                 sensor1=1
                 sensor2=0
     local data=simPackFloatTable({sensor1,sensor2})
     simSetStringSignal(modelName..'_CBS1',data)
Post by coppelia » 06 Aug 2018, 19:20
If you need a global variable, why not use a string signal for instance?
e.g. sim.setStringSignal('signalName',sim.packTable(...))
fullmanido
Post by fullmanido » 07 Aug 2018, 22:05
fullmanido
Post by fullmanido » 20 Aug 2018, 12:58
Found the decent way to use without too use Globals much time slice, used the UR5 test simulation.
--NON THREADED
if if simGetSimulationState()~=sim_simulation_advancing_abouttostop then
        if simReadProximitySensor(sensor)>1 then
             simSetFloatSignal('testvalue2',9)
        if simReadProximitySensor(sensor)<1 then
             simSetFloatSignal('testvalue2',8)
--THREADED SCRIPT
--PLACE IN WHILE STATEMENT
         t=simGetFloatSignal('testvalue2')
              if (t) then
                  if(t)then
                       if(t<9) then
                          print("the value is less than 9")
                        if(t>8) then
                          print("the value is greater than 8")
