wheel joint roll in place?
xianxjm
Post by xianxjm » 08 Aug 2018, 09:40
I use simSetJointTargetPosition to control my robot in vrep,but it cann't move .
The wheel joint roll in place .I set the friction of material, but it still doesn't work.
Thanks for any help.
Re: wheel joint roll in place?
Post by coppelia » 08 Aug 2018, 18:32
are you sure that your wheel is dynamically enabled? Make sure to carefully read this page.
xianxjm
Post by xianxjm » 09 Aug 2018, 03:28
coppelia wrote:
08 Aug 2018, 18:32
Yes, I'm sure my wheel is dynamically enabled.
The dynamically icon on its left in the scene hierarchy.
I don't know how to post a photo in this forum,but I'm sure my joint is dynamically enabled.
thanks.
Post by coppelia » 09 Aug 2018, 10:46
Are you sure that the wheel is attached to a dynamic, and not a static part? e.g. your robot casing could be suspended in the air.
Otherwise, try to post your scene, e.g. via dropbox or similar.
