Vertical movement sensor
Locked
lukebarber
Post by lukebarber » 08 Aug 2018, 16:28
I posted this question in the forum yesterday. But for some reason I cannot find it again. I'm sorry if this is a double post.
I am wondering if anyone knows a sensor that only detects a vertical up and down movement?
I came across a sensor that could work for my application but it's very expensive.
I thought of using a single axis accelerometer but the sensor will be rotating in my application. I tried using an altimeter/pressure sensor; but it was too sensitive to interference from local airflow near the sensor.
The location is not fixed. I may have to get a 3DOF or 9DOF IMU and read out only one of the axes. I'm not sure if it would work either.
Any suggestions would be greatly appreciated.
Re: Vertical movement sensor
Post by coppelia » 08 Aug 2018, 18:42
your previous post was removed, since this is not related to V-REP.
Locked
