Callback for selecting DrawingObjects
vrepUser1
Post by vrepUser1 »
is there a callback which will be executed in a plugin, when I select a DrawingObject in a scene?
And if not, its possible with eventcallback "key_pressed"? And/Or with a ray which hits the drawingobject to identify it?
Best,
vrepUser1
Re: Callback for selecting DrawingObjects
I think drawing objects cannot do the interaction you request.
Try to create a physical object (e.g. a mesh).
What are you trying to do?
vrepUser1
Post by vrepUser1 »
Hi fferri,
I'm representing some entities through line drawing objects and this entities have some specific attributes which I want to display through a cutom gui when you click on it.
I found that the "sim_message_eventcallback_proxsensorselectup" is doing what I requested for. But yes I get a '-1' as handle from this callback message, because it doesnt have a real handle like an object. But perhaps we can work with this, because he recognize the click on the line.
Now how can I get the line handle from the mouse click coordinates, which the callback also provides as information?
According to the callback auxiliary data (handle, mouse coordinates) I thought about this way:
1. handle == -1
2. if 1. is true, then continue with 4.
3. if 1. is false, ignore and return
4. check if there is a line drawing object crosses this mouse coordinate and give me the handle, otherwise return
5. fire custom line callback
Challenge: How can I check if the line is crossing the mouse coordinate in an efficient way? I can go through all generated lines with there start and endpoint, create a analytical geometrical line representation an check for the distance (with a suitable threshold) between the line and the mousecoordinate( e.g. with normalform of an line). I think this should work, but is this the most efficient way to iterate thorugh each line?
Best
vrepUser1
As I said, use an object such as a shape, a mesh, an octree or a point cloud. Those objects can register mouse clicks.
