Cannot load scenes with Python API
easonok
Post by easonok » 03 Sep 2018, 22:29
I need to run a simulation repeatedly for 3 times and collect data from each simulation, thus I am trying to use the simxLoadScene() and simxCloseScene() functions to do so.
Here is what I am doing:
1. Create a clean, brand new scene in VREP.
2. Add
    simRemoteApi.start(19999)
to the new scene in a remoteApiCommandServer.
3. Start the simulation for the brand new scene.
4. Run this Python API script:
print ('Program started')
vrep.simxFinish(-1) # just in case, close all opened connections
clientID=vrep.simxStart('127.0.0.1',19999,True,True,5000,5) # Connect to V-REP
if clientID!=-1:
    print ('Connected to remote API server')
    for _ in range(0, 3):
    	# Loading the scene
    	ret = vrep.simxLoadScene(clientID, "PATH TO THE DESIRED SCENE", 0, vrep.simx_opmode_blocking)
    	print (ret) # Returns 8 right now, which means there is a server error.
    	# Start the simulation for the desired scene
   	ret = vrep.simxStartSimulation(clientID, vrep.simx_opmode_oneshot)
    	print (ret) # Returns 1 right now
    	######### Collect data in the current simulation. ##########
    	# Stop simulation and close the scene
    	vrep.simxStopSimulation(clientID, vrep.simx_opmode_oneshot)
    	vrep.simxCloseScene(clientID, vrep.simx_opmode_blocking)
    # Before closing the connection to V-REP, make sure that the last command sent out had time to arrive. You can guarantee this with (for example):
    vrep.simxGetPingTime(clientID)
    # Now close the connection to V-REP:
    vrep.simxFinish(clientID)
else:
    print ('Failed connecting to remote API server')
print ('Program ended')
However, I am not able to load the scene. I was looking at the VREP GUI and the desired scene was never loaded up on there.
Also, no data was collected in the process, thus I am sure the scene wasn't loaded (the script for the collecting of data worked well when I just opened the desired scene and ran it).
Any idea why this didn't work? I am not very familiar with the remote API yet so any help will be appreciated!
