I used the Remote Api function "simxGetObjectOrientation" to get the orientation of e_puck, and I get it.
But I noticed that the angle Beta changes between [-90,90] degree, and there are 2 possipilities for each angle between that range. I want to get the orientation of e_puck in this range [0,360] to determine the motion of it. How can I do it?
I'm new in Vrep and I need help.
Thank's.
Orientation of e_puck
Re: Orientation of e_puck
not all 3 Euler angles are able to vary between -pi and +pi. This is a particularity of Euler angles. Typically:
- Euler alpha can vary between -pi and +pi
- Euler beta can vary between -pi/2 and +pi/2
- Euler gamma can vary between -pi and +pi
Thank you fferri for your reply. It helped me alot.
Regards.
Regards.
