How do I use Ompl to generate the correct path?
sean40471149
Post by sean40471149 » 13 Oct 2018, 08:21
Hello!
I want to build a UR5 robotic arm with a probe, and the ability to dodge a path moves to a specified point, but I have some questions about dynamic simulation and self-collision to ask.
I use the UR5 robotic arm with a fixed probe as the whole object, but when I use Ompl to plan a Dodge path, the result is less than expected, and tip and testTarget do not have a complete correspondence when planning a specified point.
Here is a schematic of my collision results.
This is my document.
https://drive.google.com/open?id=19a9Aq ... UsRM8vKBZt
Are there any omissions in the program or Object properties settings?
Please help me, thank you!
Re: How do I use Ompl to generate the correct path?
Post by fferri » 15 Oct 2018, 07:56
It may happen that OMPL does not find a path (due to insufficient planning time given).
You should check the path variable.
sean40471149
Post by sean40471149 » 15 Oct 2018, 08:51
HI, fferri
The reason may be due to a collision path variable caused it? Or with other settings?
Thank you
Post by fferri » 16 Oct 2018, 11:01
Just an additional note: that example scene might be overly complicated.
If you follow the manual page of the OMPL plugin, it gives you the list of functions to call (exactly in that order):
which is the most minimal set of instructions to create and solve a planning task.
sean40471149
Post by sean40471149 » 19 Oct 2018, 08:19
HI, fferri
After that, I redo the entire file and reduce the complexity of the scene and find it working properly!
Thank you so much.
