Problem with installing UI on V-rep
je67101
Post by je67101 »
I faced some problems with installing UI on V-rep.
I could not find the detailed tuition about UI.
Could you offer the tuition to install UI step by step?
Thank you.
Re: Problem with installing UI on V-rep
not sure what you are talking about... are you referring to the custom UI plugin?
je67101
Post by je67101 »
Yes, the current problem is Qt can't connect with V-rep.
So I can't control the model in V-rep by Qt's UI.
Hi je67101,
please report all the steps you tried, and what failed, including any relevant error messages you see in the terminal and/or in the V-REP's status bar.
It is not possible to help you otherwise.
