Reset graph
Rose111
Reset graph
Post by Rose111 » 25 Oct 2018, 16:02
I want to plot data user defined and reset the graph every 10 seconds. the following code which i used it for that.
But I have failed in this mission.
t=sim.getSimulationTime()
        if (t%10 == 0)then
            sim.resetGraph(graphHandle)
could you help me please?.
Best Regards.
Re: Reset graph
Post by coppelia » 05 Nov 2018, 08:36
are you sure that your graph is flagged as explicit handling?
In that case you are also in charge of doing the same things the main script does, to your graph.
