Questions about simulation step setting
ga89bak
Post by ga89bak »
Hi all,
I'm now making a self balancing robot in vrep. The controller part is programmed by language C. My robot works well if I slow down the simulation step to 5ms(with default value of 50ms). However when I set the default value to 5ms, my robot run in a bad behavior.
I'm confused by the simulation step setting in V-Rep. What is the relationship between vrep simulation steps and the sampling frequency of C controller? Is this means that my controller is not good enough if the robot cannot run with default simulation steps?
Thank you
Re: Questions about simulation step setting
for what you want to achieve, it is very important to run your C client synchronously with V-REP (i.e. run the remote API in synchronous mode).
