OMPL can't find path
Swistakowaty
Post by Swistakowaty » 31 Oct 2018, 16:27
I am using OMPL plugin for path planning. I build a simple scene with two obstacles and basically copied your script from 3DoFHolonomicPathPlanning.ttt. The problem is that used algorithm cannot always find a path. There are certain obstacle configurations which cause collision (most of the times “Box” hits a second obstacle). I tried to apply different algorithms and various settings but results were always similar. I am really clueless what the problem is.
Here is a link to my scene
https://drive.google.com/open?id=10PH1u ... kAKq88V-Qt
Are there any omissions in the program or Object properties settings?
Thank you.
Re: OMPL can't find path
Post by fferri » 02 Nov 2018, 10:00
The goal configuration is out of bounds.
I changed state space bounds to:
ss={simOMPL.createStateSpace('2d',simOMPL.StateSpaceType.pose2d,robotHandle,{-1.5,-1.5},{1.5,1.5},1)}
and it began finding the solution.
Swistakowaty
Post by Swistakowaty » 02 Nov 2018, 16:07
Thank you!
