V-rep with ROS running across two machines
Destine_Yang
Post by Destine_Yang » 02 Nov 2018, 02:19
I have install ROS Indigo both on my laptop and desktop, and they can share information after configuring their IP address. Now, I have MATLAB/Simulink (with robotics system toolbox) installed on my desktop and V-rep installed on my laptop. However, I couldn't use my simulink model to control the simulted robot arm in V-rep.
I tested successfully that my Simulink model can control the simulated robot in V-rep when MATLAB/Simulink and V-rep are installed on the same computer. I guess it is because the V-rep on laptop cannot publish messages to and subscribe messages from Simulink on desktop. I wonder if it is possible to run MATLAB/Simulink and V-rep on two machines with ROS running across them? If it is possible, how to implete it?
Thanks,
Destine
Re: V-rep with ROS running across two machines
Post by fferri » 02 Nov 2018, 09:51
This looks like a ROS problem and not a V-REP problem.
Some useful links:
Destine_Yang
Post by Destine_Yang » 04 Nov 2018, 20:38
Yes, it is a ROS problem. Thanks a lot for your reply! I'm currently using V-REP 3.3.1 on Ubuntu 14.04 with ROS Indigo. The V-REP ROSinterface plugin works well, i.e., V-REP can publish and subscribe messages to and from ROS. However, after installing Phantom Omni device driver and OpenHaptics toolkit, I cannot run V-REP in terminal anymore. It gives the following error:
## Error: could not find or correctly load the V-REP library.
Then, I tried sudo ./vrep.sh but obtained the following error:
##Plugin 'Ros': loading...
[FATAL] [1541360232.062171555]: ROS_MASTER_URI is not defined in the environment. Either type the following or (preferrably) add this to your ~/.bashrc file in order set up your local machine as a ROS master:
export ROS_MASTER_URI=http://localhost:11311
then, type 'roscore' in another shell to actually launch the master program.
Do you have any idea about it?
Post by fferri » 05 Nov 2018, 09:20
Don't know about Phantom driver.
You see that error because sudo resets environment variables, including ROS_MASTER_URI.
Anyway, running V-REP as root cannot be of any help, so don't do it.
