How to make the object frame parallel to the defined frame in stl file.
xzbreeze
Post by xzbreeze »
Hello
When a .stl object is imported, the frame of the object is different the frame defined in .stl.
Would you please tell me how to make the object frame parallel to the defined frame?
Thanks,
Zhe
Re: How to make the object frame parallel to the defined frame in stl file.
typically, STL files do no contain any frame information. It is just a collection of vertices and indices. Once you have imported a shape, V-REP will define a frame around the shape in a way as to minimize the volume of the bounding box. You can however change the bounding box / frame by selecting the shape, then navigating to [Popup Menu --> Edit --> reorient bounding box --> ...]. Have also a look at this page.
xzbreeze
Post by xzbreeze »
coppelia wrote: 12 Nov 2018, 11:10 Hello,
Thank you very much.
