The setting of friction in the Vortex engine
cherishTM
Post by cherishTM »
In the Vortex engine, how to set the frictional force on the ground is simulated.
Re: The setting of friction in the Vortex engine
you would do that in a shape's material properties.
cherishTM
Post by cherishTM »
hello,
Thank you very much for your reply. I can't understand the meaning of those parameters and can't meet the requirement after setting.I tried to see the official website of vortex, but I did not find any information about it.
Looking forward to your reply, thank you again.
Well, you will have to try.
With Vortex you have much more options. So, for instance, to change the friction, simply change Friction coefficient under Linear primary axis. The Linear secondary axis's fricition is the same by default as the linear primary axis, but you can change that (then you would have two different friction coefficients for the two axes)
