path generation
path generation
Please, am new here and I am using remote api python, can someone show me by example how i can generate a path along a simple object with robot arm. thanks in anticipation
Re: path generation
your question is too wide. Also, if you are new with V-REP, try to go one small step after another. For example, before trying to do what you are trying to do, simply do it without the remote API. Also, have a look at the numerous scenes and models that come with V-REP, and that can inspire you (you can inspect all code and learn a lot from it). Also, there are some tutorials that could also be beneficial.
