Getting Object Matrix from V-REP
robotico
Post by robotico » 27 Nov 2018, 00:12
I work on a quadricopter project. I use MATLAB on client side. The connection established via RemoteAPI that works on synchronized mode.
As known, we can get the object matrix with
sim.getObjectMatrix(d)
function easily. To be able to use that matrix on MATLAB side, I use
simxUnpackFloats()
or
vrep.simxGetFloatSignal
functions. I tried to get complete matrix in one step or get matrix members individually.
The problem is that, the matrix I get from V-rep is belong to previous simulation step. So I cannot get the current matrix.
How can I get the instantaneous object matrix in MATLAB?
Note: All scene elements' frame are different. For example, in my project I use global frame, quadricopter frame, kinect frame and kinect RGB frame. Their axes are in different orientation. Why did not developer select to create each's frame in same orientation? Because, to be able to handle all orientations with a 6-DoF system is already hard.
Thanks.
Re: Getting Object Matrix from V-REP
Post by coppelia » 27 Nov 2018, 08:41
you can't, unless you handle this directly inside of a child script. Typically, a simulation step is:
  • Action
  • Sensing
  • Display
  • t=t+dt
  • handle remote API communication
See also the second-last diagram at the bottom of this page.
robotico
Post by robotico » 03 Dec 2018, 13:25
I think I solve it. In Lua side I created a function using sim.getObjectMatrix and returning Matrix values individually.
Lua side:
robotMatrixCalc=function(inInts,inFloats,inStrings,inBuffer)
robotHandle=sim.getObjectHandle('Quadricopter_base')
robotMat=sim.getObjectMatrix(robotHandle,-1)
return {},{robotMat[1],robotMat[2],robotMat[3],robotMat[4],robotMat[5],robotMat[6],robotMat[7],robotMat[8],robotMat[9],robotMat[10],robotMat[11],robotMat[12]},{},'' -- return a string
And in the Matlab side, I get the instantaneous matrix with vrep.simxCallScriptFunction command through "retFloats" array.
Matlab side:
[res, retInts, retFloats, retStrings, retBuffer]=vrep.simxCallScriptFunction(clientID,'GetMatrixFunction',vrep.sim_scripttype_childscript,'robotMatrixCalc',[],[],[],[],vrep.simx_opmode_blocking);
Do you confirm that solution?
Post by coppelia » 05 Dec 2018, 11:07
That looks correct.
robotico
Post by robotico » 07 Dec 2018, 00:32
Thank you very much!
