V-REP on Ubuntu runs 2x slower than on Mac or Windows
Posted: 07 Dec 2018, 15:02
by symlee18
Hi, I'm observing that identical code runs with a real-time factor of 0.90 on a Mac Sierra and 0.41 on Ubuntu 16.04. I expected similar simulation speeds as both are high performance computers (Mac Pro with i5 4 cores 3.1 Ghz, and Dell with i7 8 cores 2.8 GHz). Would you know why this may be happening and how to increase the simulation speed on Ubuntu?
I've included links to relevant V-REP screenshots below and can also provide a link to the code if it would be helpful.
V-REP on Mac: https://www.pastepic.xyz/image/0fWrr
V-REP on Ubuntu: https://www.pastepic.xyz/image/0ftlw
I observed a real-time factor of around 0.90 on a Microsoft Surface Pro 4, i7 2017 as well.
Re: V-REP on Ubuntu runs 2x slower than on Mac or Windows
Posted: 10 Dec 2018, 14:56
I suspect that rendering is the culprit. You can see the rendering time in the Window bar.
Posted: 11 Dec 2018, 03:38
by symlee18
I think you're right. When I use the embedded video recorder in V-REP, the simulation is recorded in real-time (which is much faster than the simulation time which is slowed down by rendering).
I've tried following the suggestions found here viewtopic.php?t=19 and turned off vsync (by editing /etc/X11/xorg.conf on Ubuntu) and experimented with the useGlFinish, vsync, and debugOpenGl parameters in V-REP's usrset.txt. I've also tried to tuning my Intel graphics card by editing /etc/X11/xorg.conf to match the configuration suggested here: https://www.techzim.co.zw/2017/06/tunin ... ntu-16-04/.
Unfortunately, the slow rendering persists. a) Is there anything else that I can do to try and speed up the rendering?
And I've also tried running the simulation in headless mode on Ubuntu but it only seems to provide around a 15% reduction in simulation time, which is lower than I expected. b) Is there anything that you suggest I do to increase the simulation speed in headless mode apart from the suggestions posted here: viewtopic.php?f=9&t=2247?
Posted: 12 Dec 2018, 11:00
Did you try to install a better driver for your graphic card?
The headless mode you are talking about is still generating vision sensor images, thus the small speed gain you see (you have 4 vision sensors in your scene from your screenshots). You could also try to play with the OpenGl settings such as offscreen context type, FBO type and/or VBO operation.
