Differences exisit in simulation with or without video recoeding
zwei371
Post by zwei371 »
Hello!
I'm doing the research on the quadruped locomotion using V-REP and MATLAB. When I used the video recording function, I found the simulation result is quite different. I wander whether there is any method to eliminate this difference.
Look forward for your reply!
Re: Differences exisit in simulation with or without video recoeding
use some external capture software such as CamStudio, Taksi, Fraps, or similar.
zwei371
Post by zwei371 »
Thanks for your reply!
I used the external video recorder, but the differences still exisited.
Do you have the real-time mode enabled? If yes, then you will definitively see differences, since video recording will slow down everything.
zwei371
Post by zwei371 »
I test on my simulation when the real-time mode is enabled or disabled. Obvious differences exist when the video recording function is on or off. Now I am trying to obtain two sets of parameters for normal simulation and recording videos.
