API differences
faisalkhan
API differences
Post by faisalkhan » 24 Dec 2018, 03:19
what is the difference between setting joint angle API and setting joint position? Are both are the same but applicable in a different mode like passive, force/torque mode? A detailed answer would be appreciated.
Re: API differences
Post by coppelia » 28 Dec 2018, 10:57
So what are the two API functions exactly that your question refers to?
faisalkhan
Re: API differences
Post by faisalkhan » 29 Dec 2018, 03:04
1)simxSetJointPosition
2)simxSetJointTargetPosition
Re: API differences
Post by coppelia » 02 Jan 2019, 13:57
sim.setJointPosition (or simxSetJointPosition) sets the angular/linear position of a joint that is not in force/torque mode. The joint will instantaneously jump into position.
sim.setJointTargetPosition (or simxSetJointTargetPosition) sets the desired angular/linear position of a joint that is in force/torque mode, and that has its controller enabled. The joint will gradually try to reach the desired position.
