How can I maintain fast simulation rate with many vision and proximity sensors?
jparkcalvin
Post by jparkcalvin » 27 Dec 2018, 08:02
I used a mobile platform with many lidar (SICK sensor), vision (kinect, camera), and proximity sensors attached.
When I ran the simulation with default simulation time (dt=50 ms),
simulation went too slow (script executed time: ~ 200 ms, vision sensor rate: ~ 140 ms).
Is there any way other than reducing the number of sensors or resolutions of sensors?
Thanks and Regards,
Calvin
Re: How can I maintain fast simulation rate with many vision and proximity sensors?
Post by coppelia » 28 Dec 2018, 11:00
yes, you can reduce the number of sampling for your vision sensors. Instead of computing (i.e. handling) your vision sensors once per simulation step, you could handle then once every 4 simulation steps for instance.
To do this, you will have to flag those vision sensors as explicit handling and call sim.handleVisionSensor yourself, when needed.
jparkcalvin
Post by jparkcalvin » 02 Jan 2019, 03:04
Thank you for the answer!!
Calvin
