The bubbleRobClient never uses simx_opmode_buffer, even though it starts streaming with
simx_opmode_continuous /simx_opmode_streaming.
https://github.com/CoppeliaRobotics/bub ... Client.cpp
Is there any advantage in using simx_opmode_buffer after starting streaming with simx_opmode_streaming, or will it have the same effect to use simx_opmode_streaming in subsequent calls?
I assume that using simx_opmode_streaming in subsequent calls might incur a tiny overhead, where it checks if streaming of the command is already active and then switches to simx_opmode_buffer automatically. It might also have to resend a command, whereas buffer mode just checks the local client buffer. Otherwise, how would the bubbleRobClient.cpp work?
Are there any advantages in using simx_opmode_buffer in subsequent calls?
simx_opmode_continuous vs simx_opmode_buffer
Re: simx_opmode_continuous vs simx_opmode_buffer
yes, the example is not very elegant, and one should have used simx_opmode_buffer in subsequent calls.
simx_opmode_streaming actually sends a command to V-REP and then uses simx_opmode_buffer to check if a reply is already there (from a previous call).
It is like you say, always using simx_opmode_streaming adds a little overhead.
Thanks for clarifying!
