Add disturbance on control signal
BiancaSan93
Post by BiancaSan93 » 03 Jan 2019, 20:34
I have a dynamically enabled joint (force/torque mode) that uses the "default" PID control loop. However, I need to access the control variable (which I assume is a torque) to do some evaluations.
How do I read the control signal? Is it possible to add an external signal to it before it goes into actuation? For reference, I need to simulate actuator failure.
Re: Add disturbance on control signal
Post by coppelia » 04 Jan 2019, 13:50
hello,
you will have to write a joint control callback function.
BiancaSan93
Post by BiancaSan93 » 04 Jan 2019, 16:38
Hi, thanks for the reply. However, I still have doubts about it, what is the control variable? Assuming I want to track it on a graph, which data stream should I pick?
EDIT: I need to know specifically the torque exherted by the joint. Is it possible?
Post by coppelia » 08 Jan 2019, 15:08
If you want to track (i.e. display) a custom value via a graph, then have a look here.
