Retrieve derivative of data stream real time
BiancaSan93
Post by BiancaSan93 » 12 Jan 2019, 20:35
Using the graph object, I am computing the derivative of the data stream plotted during the simulation. How can i retrieve that value (i.e., after performing derivative on the signal) at each step in a script? I figured sim.handleGraph would do the trick but I don't understand where the result is stored, seems just a flag for succesful operation.
Re: Retrieve derivative of data stream real time
Post by coppelia » 16 Jan 2019, 08:24
you can't directly extract computed values in a graph. You can only copy a curve to the clipboard or export a graph.
The best would be to compute that derivative yourself, inside of a child script.
