Parametric model of robot arm
MajorTom
Post by MajorTom » 28 Jan 2019, 11:38
I am trying to find an easy way to create a model of a robotic arm where I can change the size of the links (lenght and diameter of cylinder) but the only way I could come up with to do this is to use the createPureShape, setObjectPosition, setObjectParent, etc. functions.
This is very cumbersome and therefore I wanted to ask if there exists a more elegant solution ?
Best regards
Re: Parametric model of robot arm
Post by coppelia » 28 Jan 2019, 15:29
yes, you can use sim.scaleObject. You might have to previously gather the current object size if you want to set a specific size, instead of just scaling the object. Following could help:
function model.setObjectSize(h,x,y,z)
    local r,mmin=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_x)
    local r,mmax=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_x)
    local sx=mmax-mmin
    local r,mmin=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_y)
    local r,mmax=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_y)
    local sy=mmax-mmin
    local r,mmin=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_z)
    local r,mmax=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_z)
    local sz=mmax-mmin
    sim.scaleObject(h,x/sx,y/sy,z/sz)
Some primitive shapes, compound shapes, and most other objects can only be isometrically scaled.
MajorTom
Post by MajorTom » 29 Jan 2019, 11:02
thanks for the fast response but using this approach will cause simulation issues as the absolute position of the parent and child object will remain the same and if the parent object is up scaled then the two intersect.
So basically I would have to rectify the position of the entire robotic arm links and joints which will cost me the same effort as creating an entirely new model from scratch, or am I missing something ?
Post by coppelia » 29 Jan 2019, 14:26
Yes, you will have to adjust the position of the scaled shapes, including the position of its children. This can be tricky, but once set-up and combined with a customization script and custom UIs, then you can quickly configure your arm via the user interface. Have a look at the model models/robots/non-mobile/ragnar.brm
MajorTom
Post by MajorTom » 29 Jan 2019, 17:01
The ragnar model is a lot of help.
Thank you!
