How to sent data to Vrep from Matlab
biscuit122
Post by biscuit122 » 01 Feb 2019, 04:01
I have tried codes in Vrep side to receive data from Matlab in a Synchronous mode.
    s=0
    lastReceivedFX=-1
    lastReceivedPos=-1
function sysCall_actuation()
local packedFX=sim.getStringSignal('packedFX')
            if packedFX then
                sim.clearStringSignal('packedFX')
                packedFX=sim.unpackFloatTable(packedFX)
                for j=1,#packedFX,1 do
                    if packedFX[j]~=lastReceivedFX+1 then
                        print('Error')
                    io.write('.')
                        lastReceivedFX=packedFX[s]
The code in Matlab side is shown as follows:
packedFX = vrep.simxPackFloats(xFoot);
vrep.simxWriteStringStream(clientID,'packedFX',packedFX,vrep.simx_opmode_oneshot);
But it is always found that packedFX in Vrep cannot output value every sampling time, but accumulate several arrays then output about more than 20 or 30 goups of value. Could you help me with finding the reason? Thanks.
