Graph set into radians per second
Posted: 07 Feb 2019, 14:41
Hi Coppelia
I am using a Graph with function Object: angular velocity (), when I plot it in XY curve it shows the velocity in degrees per second, how can I measure in rads per second?
Morevover I use Graph with function Object:absolute velocity() in order to graph at XY curve the linear velocity of the robot only. Is that correct?
