ROS interface automatically adds prefix to a service topic
Filipe Rocha
Post by Filipe Rocha »
Hello everyone.
I am using vrep_ros_interface to communicate my simulation with ROS.
When advertising a service, I use the following LUA command:
serv_handler = simROS.advertiseService('/srv_topic', '/std_msgs/foo', 'my_service_callback_function')
However, the interface generates a service topic with the following name:
/vrep_ros_interface/srv_topic
It automatically adds the /vrep_ros_interface prefix. This is a problem for my application, as we are replicating a real robot interaction and the real service does not have this prefix.
Is there a way to remove that prefix?
Thank you in advance, and congratulations for the awesome simulator!
Re: ROS interface automatically adds prefix to a service topic
RosInterface does not add any prefix.
This is the Lua callback for simROS.advertiseService, and this is the included srvsrv.cpp which calls NodeHandle::advertiseService, as you can see it passes in->serviceName (the string "/srv_topic" in your case) directly to ROS.
Have you tried using "srv_topic" instead of "/srv_topic"?
Can you post the output of "rosservice list"?
