How to access the stack trace from the external API
agsdyson
Post by agsdyson » 07 Mar 2019, 15:43
I'm using python to call the external API to do some simulation.
if I use the python external API to call "sim.setObjectName()" with the incorrect arguments the stack trace output is:
Lua runtime error: [string "CHILD SCRIPT remoteApiCommandServer"]:51: The function requires more arguments. (sim.setObjectName)
stack traceback:
	[C]: in function 'setObjectName'
	.../workspaceAnalysis/pyvrep/scenes/lua/createRobot.lua:51: in function 'createJoint'
	.../workspaceAnalysis/pyvrep/scenes/lua/createRobot.lua:68: in function <.../workspaceAnalysis/pyvrep/scenes/lua/createRobot.lua:59>
Error: [string -unknown location]:?: Call failed. (simCallScriptFunctionEx on createJointEx@remoteApiCommandServer)
However, if I call vrep.simxGetLastErrors() from python the returned value is:
['Object does not exist. (simGetObjectHandle)', 'Error in script function. (simCallScriptFunctionEx)']
The error is technically correct, but not very useful for debugging compared to the stack trace.
I've also tried looked into looking at the terminal output of the process that was used to launch vrep.sh, but the stack trace is not printed there.
Is is possible to get the stack trace through the external API or terminal stdout?
Re: How to access the stack trace from the external API
Post by coppelia » 08 Mar 2019, 13:13
hum... maybe one of following 2 methods?
function test3(n)
    local a=sim.getObjectHandle(n)
    return a,"hello"
function test2(n)
    return test3(n)
function test1(n)
    return test2(n)
    local method1=true
    local objectName='notExistingObject'
    if method1 then
        local co=coroutine.create(test1)
        local result,retArg1,retArg2=coroutine.resume(co,objectName)
        print(result,retArg1,retArg2)
        print(debug.traceback(co))
        local result,retArg1,retArg2=xpcall(function() return test1(objectName) end, debug.traceback)
        print(debug.traceback())
agsdyson
Post by agsdyson » 14 Mar 2019, 16:57
Thanks. I've been playing around with those functions, but the debug.traceback() does not seem to have as much information as the stack trace in the status area.
Post by coppelia » 18 Mar 2019, 15:07
In V-REP V3.6.1 rev1, available within one day, you can use: sim.getStackTraceback
agsdyson
Post by agsdyson » 19 Mar 2019, 16:36
Thank you, this will be very helpful for debugging.
