running scripts
luberdis
running scripts
Post by luberdis » 13 Mar 2019, 11:59
Hi Coppellia
I use non-threaded child script to run my simulation. The problem is that I want to use two algorithms which the first must be completed before the second starts. From the moment that the entire script executes iteratively like a giant while loop process, how can I use two controllers in series not parallel?
Re: running scripts
Post by coppelia » 13 Mar 2019, 14:14
since non-threaded child scripts are constantly called (and also constantly need to give control back), you could do something like:
    task1Finished=false
    task2Finished=false
function sysCall_actuation()
    if not task1Finished then
        -- compute iteratively task1
        if not task2Finished then
            -- compute iteratively task2
But better would be to use a threaded child script.
