Set up dependent joint from lua api
agsdyson
Post by agsdyson » 15 Mar 2019, 10:49
I have set up a dependent joint using the gui and everything behaves as expected.
I am generating robots programattically using the lua api and so far I have not been able to create a dependent joint from lua code.
I can use:
sim.setJointMode(sim.jointmode_dependent)
but I can't find an api function that specifies the dependancy equation or the joint that the newly created joint depends on.
These are the closest functions to what I want to do, but I am not using the vortex or newton engine so they don't have the desired effect.
sim.vortex_joint_dependencyfactor (float parameter)
sim.vortex_joint_dependencyoffset (float parameter)
sim.vortex_joint_dependentobjectid (int parameter)
sim.newton_joint_dependencyfactor (float parameter)
sim.newton_joint_dependencyoffset (float parameter)
sim.newton_joint_dependentobjectid (int parameter)
The dependent joints created in the GUI work the ODE physics engine. Is it possible to recreate this behavior using only the lua api?
Re: Set up dependent joint from lua api
Post by coppelia » 18 Mar 2019, 15:01
correct, that functionality is missing. Try downloading V-REP V3.6.1 rev1 in about a day, then you should have a new API function: sim.setJointDependency
agsdyson
Post by agsdyson » 19 Mar 2019, 15:47
Thank you, that is very helpful!
