at the moment, I try to make a communication between child scripts.
In my threaded child script, I can get integer Signals from the non-threaded child script:
For example, in non-threaded child script: setting Integer Signal with...
sim.setIntegerSignal('DropLimit',20)
-- get drop limit from Vision Sensor script
shapeDropLimit = sim.getIntegerSignal("DropLimit")
But now: I want to set an integer signal in the threaded child script and get it in the non-threaded child script to start an action in it, but it doesn't work...
I need your held. Is there any solution to set a signal in a threaded script and read it in a non-threaded script?
Thanks from Germany...
Regards Marimo
