Hi, coppelia
I am working on controlling the robots in vrep by a c++ client. However, different form the IDE used by BubbleRobClient example, I develop the project in QT creator instead of Visual Studio. I add the files in the directoris of include and remoteApi to the project ,set the pre-compiling definitions and add the absolute path of remoteApi.dll in the pro file like the follwing:
When I build the project, an error says remoteApi.lib cannot be opened. However, I cannot find any file with the suffix lib with the vrep directory. I have been stuck for one day and I really appreciate it if any one could help me!
The problem is solved by the following two modifications in the pro file:
1. add "DEFINES += DO_NOT_USE_SHARED_MEMORY"
2. cancel "LIBS += ..."
However, I am not clear the effect of DO_NOT_USE_SHARED_MEMORY
