Simulation stops when getting data from a 3D Laser scanner
xli4217
Post by xli4217 » 02 May 2019, 23:09
I am using V-rep with Python Remote API. The 3D Laser scanner (provided in Model browser) is based on a vision sensor. I can get the measuredData which contains all the points that are closer than the sensor range. I used the function
sim.setStringSignal("measuredData",data)
to send the data, and I used the function
vrep.simxGetStringSignal(self.clientID, "measuredData",vrep.simx_opmode_streaming)
vrep.simxUnpackFloats()
in the Python script to get the data.
However, every time I run the python code, the simulation in V-rep will slow down a lot or even stop. Any suggestions to solve this problem? Thanks.
Re: Simulation stops when getting data from a 3D Laser scanner
Post by coppelia » 07 May 2019, 10:02
Difficult to say what is going on with the little information you are providing...
