How to implement the application of external TCP?
For example, a robot arm grabs an irregular object Grinding a circle of trajectory(use path) on a fixed grinding wheel.
At this time, the grinding wheel is fixed and the robot arm is moving.
About robot External TCP
Re: About robot External TCP
Thank you for answering my questions.
I tested model is ABB IRB4600 from vrep robot library
