Tool change and fixed orientation of tool in industrial simulation
altella
Post by altella »
Dear all,
A student of mine is trying to simulate an industrial procress using a Kuka robot in VRep.
We are stuck solving two things which are common in industrial setups: A tool chage operation and a linear movement with the robot tool mantaining a fixed orientation.
Related to tool changing, we found this topic in the forum:
http://forum.coppeliarobotics.com/v ... .php?t=623
My student has tried to follow instructions to change the tool of the robot, and initially has commented that they work if the union robot-tool is for the complete simulation. We would like to change the tool in the middle of the simulation, this is, grab the part with a gripper and then change tool and drill the part. Can this be done in vrep?
For robot orientation we found this other topic:
http://forum.coppeliarobotics.com/v ... ?f=9&t=575
Again, my student says this works if the part has no "parent", if he follows the procedure, he places the tool with a fixed oriention with respect to the last joint of the robot, and them moves with the robot. How to perform a linear movement in Z with a fixed orientation of the tool?
Thank you in advance for your help,
best regards,
Alberto
Re: Tool change and fixed orientation of tool in industrial simulation
yes, you can change object parenting also when simulation is running. If your end-effector (or tool) is dynamically enabled, you will probably have to reset that model appropriately, as explained here for instance.
If you want to follow a particular path (e.g. a straight line) and/or keep a specific tool orientation, you will have to work with IK.
