Using Spherical joint connect Prismatic joint
ZZhang
Post by ZZhang »
Hello all,
In my scenario, I structured a cable robotics and I using a spherical joint to constraint a prismatic joint to simulate the motor which could release/tighten cables. the structure is shown as follow:
Shape --> Spherical Joint --> AuxShape --> Prismatic Joint --> Cable Shapes/Joints --> End Effector
However, when the cable is tighten, the Prismatic Joint would rotate to opposite side of Spherical Joint after one shape is dragged through Prismatic Joint which is not intended. Could anyone explain this and it would be very helpful.
Cheers.
Re: Using Spherical joint connect Prismatic joint
I am not sure at all that I understand what you mean. Please post a scene illustrating your problem,
